07-19-2013 07:25 AM
I am using HP IntuiLink for oscilloscope screen capture and I switched from an HP I-O card to NI488.2
Now I do not see the NI488.2 in InuiLinks configure options.
What can I do to get good screen capture again from the HP54645D Oscilloscope?
Thanks in advance,
Bertho
07-30-2013 03:27 PM
Hi Bertho,
NI 488.2 is a driver package. The following document walks through setting up and configuring your system with the NI 488.2 drivers and communicating with your instrument through the NI Measurement and Automation Explorer.
http://www.ni.com/pdf/manuals/370428l.pdf
If that is not able to solve your problem, we will need more information about your hardware setup. Are you now using a National Instruments GPIB card?
If you are not using LabVIEW or other National Instruments hardware/software, you may need to contact Agilent for help with IntuiLink.
Kelsey Johnson
Applications Engineer
http://www.ni.com/support
(866) 275-6964
07-30-2013 03:51 PM
Thanks Kelsey,
I bought the National Instrument's NI 488.2 highspeed card.
After a lot of testing I finally got everything working.
Thanks again.
Bertho
