02-19-2016 07:08 AM
Hi all
I'm well aware that labview wil by default instal driver en the "Labview\instr.lib" folder but is it posible to install drivers on a network location so it can be shared?
I'm asking this since I like to code my applications on my desktop computer. But if they need to run for an extended period of time, I like to run the aplication on my laptop. witch means that I have to copy the instrument driver to my laptop, and any "small" fixes needs to be copyed back to my desktop.
I gues a similar situation would arise if there was more than one man using, and "improving" the driver.
/Regards Rasmus
02-19-2016 07:43 AM
Sounds like a use case for a Software Code Control software, such as SVN. That way you have a repository on the server and then you commit changes to the repository and pull updates from it.
