Reply
Instrument Driver of LabView
I cannot find the drivers of the following instruments for LabView on NI's site,
ADVANTESTSmiley Very Happy3286/D3186/R6142/
Agilent:1682A/81250A/89611A/E5071B/89600S/E8403A
HP:8971C
Are there any recommended websites that you can recommend to me?
(1,190 Views)
Re: Instrument Driver of LabView
There are a few options for you to try:
1. Contact the instrument manufacturer to check if they provide LabVIEW drivers for their instruments. If Agilent has VXIplug&play drivers for these instruments, you can then use the "LabVIEW Interface Generator for LabWindows/CVI Instrument Drivers" tool to import the VXIp&p driver into LabVIEW. Please refer to http://www.ni.com/devzone/idnet/development.htm for more information about this tool.
1. Post your question on Info-labview: http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/2c7719d63fe1e83c8525646000503b72?O...
2. Use Instrument I/O Assistant in LabVIEW
to communicate with message-based instruments and graphically parse the response. For example you can communicate with an instrument that uses a serial, Ethernet, or GPIB interface. Refer to the Instrument I/O Assistant Help for more information about communicating with an instrument.: http://digital.ni.com/softlib.nsf/websearch/F3CA0298C715BCD886256E82005758E5?opendocument&node=13206...
3. If you have access to any documentation containing the command set for the instrument, you can try to develop a driver yourself (http://www.ni.com/devzone/idnet/developid.htm)
4. Contact our Alliance Member. Many of our Alliance members have extensive instrument driver development expertise. For a listing of our Alliance Members, go to: http://www.ni.com/alliance.
Vesna
(1,179 Views)
