05-02-2014 11:57 AM
I am trying to initialize a session to an Agilent N5764A. I keep getting an error code -1074001254 saying
N5700 Write to Instrument -> Config
Voltage Limit.vi -> N5700 Getting Strarted.vi ->
Agilent 5700 Initialize.vi ->
<ERR> Error sending N5700 Command:
:VOLT 0
<ERR> n5700 "SYST:ERR?" returned:
-410, "Query INTERRUPTED"
The weird thing is that I have 2 of these agilents connected to a PXI Box via GPIB. One of them has address 5 and the other 6 (the one giving the error). When I change the address to 5 and re-run the .vi, it initializes and works fine. I am using the built in tlabview initialize function, and i have tried closing, clearing the visa session, as well as restarting the computer, and also moving around the GPIB connections to no avail. Any advice would be great.
Solved! Go to Solution.
05-02-2014 06:23 PM
05-02-2014 06:39 PM
I came to the realization that I was trying to configure a 3rd agilent that was connected to the system, expcept it was a different model number so i was using the wrong .vi. Thanks for trying to help however.
