I need a bit of help for the proper usage of the Channel and Measurement interface of IVI-COM driver. I have a sucessfully used the Active-X Automation Open, then the intiate methods via the class browser. Also know that there is communication with the device as some various properties can be set, but Im a bit stuck on the correct way to wireup and use the Measurements on Channel. In C# the syntax is myMeter.Channels.Items["CH1"].Measurements.FetchCwPower or FetchWaveform.
Pretty sure the Channels interface down Wiring down to the Channel, then passing the name in a constant, then to Measurements. But the Blue IsValid input and output wire connection are throwing me off, and causing labview to bomb. Any basic help with or example vi using IVI-COM and iviPwrMeter and the Channel Measurements would be appreciated!!
