04-10-2015 10:52 AM
Hello All,
Set-Up:
PXI-1033 connected through MXI to a PC running Windows 7. LabVIEW 2014. TestStand 2014 (32-bit). PXI-4110 Power Supply and PXI-4070 DMM.
In MAX I can open both soft panels and control both units and they work great. In LabVIEW I can control both cards as well.
In MAX I have set up a driver and logical name for my DMM. This unit works great within TestStand using an IVI DMM step.
I then proceeded to setup the 4110 in MAX with an IVI driver and logical name. Here are my settings:
Hardware: Added hardware asset and select the PS. This one is checked, no other assets are checked.
Software Module: NI-DCPower, 4110 is listed as a device that is supported.
Virtual Names: This is where I am confused, Under physical name there are four options that come up (0, 1, 2, and 3). This power supply only has 3 outputs so I am unsure why four come up. I have made 4 virtual names, one for each of the options. I named them ch0, ch1, ch2, and ch3 respectively.
When I put an IVI Power Supply step in TestStand everything seems to be working. I open the configuration window and set my values for each channel. If I try to validate the setup by unchecking simulate and click on init I do not get an error. As soon as I clic on 'Configure' or 'Show Soft Front Panel' I get the following error:
"The IVI Configure operation failed for lgical name 'NI PS 1'. Details: Extention capability not supported by instrument driver. (Base) (-30717)"
Any information would be appreciated. I tried playing with it for a couple hours yesterday and had a couple co workers try to help. We are all under the assumption that this should be working.
Thank You!!
Jesse
Solved! Go to Solution.
04-13-2015 02:08 PM
Hi jesserzamora,
Have you seen this link: http://digital.ni.com/public.nsf/allkb/331F2717DBCD1F858625758200745773?OpenDocument
It discusses a similar failure with the IVI Power Supply step in TestStand.
04-13-2015 03:00 PM
Thanks so much. I hadn't seen this article. This helped me solve my problem.
Jesse
