03-26-2012 03:37 AM
Hallo,
I have a IT6322 Programmable Power Supply from Itech and I would like to interface it with TestStand.
Do you know if a driver for this instrument exist?
Thank you for your help.
03-26-2012 07:39 AM - edited 03-26-2012 07:39 AM
Did you try looking in the Developer Zone section and clicking on the "Instrument Drivers" link? That would take you to the Instrument Driver Network page where you can search the database of available drivers. There is no driver for that specific model. I don't see any drivers for Itech. This means you can either take an instrument driver for a similar power supply and modify to fit how the IT6322 works (i.e., changing the command strings), or you can write your own, which is not all that difficult. I would suggest starting here: http://zone.ni.com/devzone/cda/tut/p/id/4359
03-26-2012 09:51 AM
You also do not mention which programming language you are using. If you want to use the built-in IVI step, you would need to create an IVI-C, IVI-COM, or IVI-NET driver.
03-27-2012 03:01 AM
Dear All,
Thank you for your answers.
I finally received the VI files from the Power Supply manufacturer.
Let me know if you would like to have a copy of them.
Best regards
08-04-2012 06:12 AM
I would like to have it ;please send to my email;
luyaoluo@gmail.com
thanks you
04-20-2017 05:06 AM
Hi Sir,
Good Day!
Can I request it from u? here's my email.. norwinjamesj@gmail.com
I have another request if u know the solution.. I need to program Itech Power supply
using Microsoft vb,c++ or c# but the problem is its hard to communicate with it since
the interface is RS232TTL type which is not typical for us.. Can u help me with this?
Thank and God Bless!
james
08-01-2018 04:51 AM
If it is still available, I would like to have a copy of the VI to control the Power Supply IT6322 .
Thank you in advance for your kindness,
Richard.
email: richard.tozzi@gmail.com
06-06-2019 02:48 AM
Can you pls share the same
C heqder file
dll file, or the LabVIEW files
