10-07-2014 02:46 AM
My name is Ricardo and I´m trying to connect a legacy HP 3852 with a GPIB to USB cable (INES branded), The drivers are recognized by W8 in the device manager and I can connect to the HP 3852 through my HPBASIC connection. However, when I start NI MAX to connect through Labview, NI MAX doesn´t recognize anything. I have tried to use VISA, but I don´t know the address of the equipment and the VISA can´t find it. I have tried to follow the manual of the INES GPIB-USB and I have copied its drivers to c:\Windows\System32 but they are not recognized nor used by Labview. ¿What can I do to connect to the HP3852 through this cable? Thanks in advance for your help.
Regards, Ricardo.
10-07-2014 07:41 AM
Regards, Ricardo.
Doesn't recognize anything?
Perhaps you should post a screencapture of your NI-MAX.
You can't just "copy" drivers. You need to install them.
10-07-2014 07:49 AM
The INES GPIB USB manual says explicitly to copy them in the c:\Windows\System32, But also the drivers have been installed in the system, but neither operations have achieved the goal. NI MAX does not recognize the GPIB USB. I attach an image, as you can see there is no GPIB interface detect, nor VISA device or anything else. I need some help to get this work.
Thanks in advance, Ricardo
10-07-2014 08:16 AM
I have an Agilent USB-GPIB adapter, and it isn't recognized in NI-MAX either.
But there are instructions on how to get it recognized in NI-MAX.
You will need to contact INES.
You chose to buy them instead of a NI product.
10-07-2014 08:19 AM
Hello NYC
I´m trying both lines, through NI and INES. I didn´t choose the cable, It was something acquired before I came to the place I work now. Can you send the instructions you had as it may give me a clue on how to install? Thanks in advance.
Regards, Ricardo
10-07-2014 08:29 AM
10-07-2014 12:44 PM
10-08-2014 03:25 AM
Thanks Dennis,
I have one question, what is the "tulip support"? Thanks for the info!
Regards, Ricardo
