08-08-2014 03:53 AM
Hi all,
I am trying to create a Labview interface for the board TI EV2400, which has SMbus and I2C ports. What I would like to do for now is just recognize the device and read the SDA... Is there a toolkit for I2C interface or how can I interact with such DSP using labview? Is the DAQ assistant ok for acquiring the signal?
Thanks in advance for your help.
Fabrizio
08-08-2014 09:06 AM
08-08-2014 09:10 AM
I know this device from NI, but the problem is that I am using the EV 2400 from TI (my boss just gave me this one)....
Can I control this with labview, or since it is not a NI instrument, it is not possible?
08-08-2014 09:51 AM
You interface to this device on its USB port using its API.
You're the engineer. Research that API.
08-08-2014 10:14 AM
08-11-2014 01:00 AM
Thanks Dennis for the help, but can you be a bit more precise please? What kind of function description I have to get? Is there a specific VI or function in the labview palette I can use to interface the board?
08-11-2014 07:20 AM
08-11-2014 07:51 AM
Working deeply on this problem, I am figuring out that probably using the NI VISA functions it is possible to control the board. I am now able to write commands via usb (then I have to traduce them into I2C), but unfortunately still not able to read data.The NI MAX Measurement Explorer does not detect any bulk in pipe, which is apparently the cause why I cannot read any input of the device - see image below).... I used then the VI VISA read /write example to do the reading, and have the same problem: I can write via the bulk out pipe, but not read (no bulk in pipe, no input detected).
What do you think of this method? is it correct? Any suggestion to detect the bulk in pipe?
I don't have any dll for the device and no idea where I could get it (not provided with the device and no trace of it on the website)...without dll I cannot call the library with the specific function
08-11-2014 07:55 AM
08-11-2014 08:01 AM
You need precise information on the functions in HID.dll that comes with Windows that need to be called
--> Sorry, what is "precise information on the functions"?
--> Should I open and modifiy the HID.dll file adding the description of my function?
I am a quiet extensive labview user (I have been using it since 8 years now) but outside that, I have not a clear idea of informatics and computer architecture, sorry!
