I would like to know a question regarding interfacing with a Yokogowa WT130 utilizing a NI GPIB-USB-HS is possible in Dasy Lab
I have a Yokogowa WT130 power analyzer and I would like to use this to communicate to DASY Lab. The Yokogowa utilizes IEEE 488 communication and I was thinking of using the NI GPIB-USB-HS to connect the Yokogowa to the computer. I do know that DASY Lab is capable of utilizing IEEE 488 but I am confused on if I would neede a seperate driver for the Yokogowa or if the driver for the NI GPIB-USB-HS would allow communication. Any feedback would be greatly appreciated.
(4,666 Views)
backhausr1,
I would recommend asking this in the DASYLab forum, which can be found here: http://forums.ni.com/t5/DASYLab/bd-p/50
You will likely get better and more prompt assistance.
(4,632 Views)
GPIB in DASYLab requires only a compatible card to talk to the device.
Other than that, you will need the programming manual for your device
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(4,629 Views)
