09-18-2008 10:37 AM
I have a serial port link that we use with Pro-Link software to configure Micro-Motion flow meters. Is it possible to utilize this connection with the Rosemount transmitter and configure the device?
Thanks for any help you may provide.
Randall
09-19-2008 10:38 AM
Can you give me further information on your application? What kind of Pro-link software do you have? What type of Micro-Motion flowmeters? Are you trying to use theHART Communicator 275? What type of National Instruments products do you have, if any?
09-19-2008 12:57 PM
LabVIEW version 4.0 - 8.6 but this application would best be LV 7.x for now. I have a VIATOR RS232 interface for HART from MACTek Corporation. We use this interface with Micromotion's ProLinkII software to configure and calibrate the F series Micromotion flow meters.
I basically want to utilize the HART interface to scale and configure the ROSEMOUNT transmitter. I do not have the HART Communicator 275. I will not be using this for acquisition but rather read the mA sig with the SCXI equipment on a 1102 module.
Thanks for responding.
Randall
09-22-2008 10:48 AM
Randall,
I've read through the documentation for all the devices mentioned, and I see no problem with using the Pro-Link software to configure the Rosemount 1151 transmitter. Both deices use the HART protocol. However, I see that in the Pro-Link manual, they have a Viator RS-232 converter cable that you might need. The Viator RS-232 to Bell 202 HART Converter with the tester and the cables. I do not know if this is absolutely required, but it wouldn't hurt to check.
I hope this helps
