If you already have created the resource and it will not let you recreate the resource, locate the visaconf.ini file (usually in C:\VXIpnp) and delete it, do NOT delete the visaconf.dll. Start up MAX again and you should be able to recreate it. What version of MAX are you using?
Hope this helps.
Russell G.
NI Applications Engineer
