There is a known issue with NI-488.2 v2.2 and instruments that return a rather long "*IDN?" response. This might be your problem. If the instrument returns more than 99 bytes, MAX will behave in this way. The workaround is to not use "Scan For Instruments" in MAX. The "Scan for Instruments" functionality is designed to help you find your instruments on the bus, but it is not required before communicating with them in LabVIEW (or other programming languages). As long as you know what primary address your instrument is using, you can simply use that when trying to communicate with that instrument.
This issue will be fixed in a future version of NI-488.2.
Scott B.
GPIB Software
