Take a look at Chapter 5 in the ZUP Manual for the command set and use hyperterminal to check the communication.
You need to start with ":ADRXX;" (XX the address of your device), followed by ":MDL?;" should give you the ID
check the communication settings: baudrate, flow control (in my case it was HARDWARE) etc.
Greetings from Germany
Henrik
LV since v3.1
