06-25-2014 09:13 AM
Any suggestions for a relatively low cost oscilloscope with a Labview 7.2 compatible driver? Interface is probably going to be GPIB.
06-25-2014 09:24 AM
06-25-2014 09:36 AM
thanksfor reply. 2 channel is fine. 1 GS/s sampling rate is adequate as is 50 MHz bandwidth. I'm trying to stay under $2000. LV version 7.1.
06-25-2014 09:51 AM
06-25-2014 10:05 AM
I am also a fan of the TDS lineup by Tektronix. Again, the drivers will likely need downconverted for you. But if you are making a new system, I would highly recommend updating your version of LabVIEW.
06-25-2014 10:14 AM
thank you both. I think I have enough to go on.
06-25-2014 10:22 AM
