I use borland C++ builder within Decl-32.h and BorlandC-gpib-32.obj
For primary address example, I used send(0,(Addr4882_t)5,"*IDN?",5L,NLend) and it worked.
But I forgot how to set the secondary address to control it.
I knew that secondary is high-bit(96-xxx) and primary is the low-bit(0-30)
I use the MakeAddr(8,98) function, it shows me that result is 25xxx.
And I try to use 25xxx in send() function, it couldn't work.
Anyone can help to tell me how to use the correct syntax in send() with secondary GPIB address???
PS: I try to use 0x9808 and 9808...it still couldn't work.... Q_Q
