07-09-2015 04:26 AM
Hallo Guys,
with the help of Assistant to Instruments I/O, I could place my instrument from the dropdown box and have selected the data entry type to GPIB followed by marking 488.2 tick box for error testing. I need some guidance in how to send, read and analyze data from the network analyzer.
Thanks in advance for the help !!!
07-09-2015 04:55 AM
07-09-2015 05:25 AM
I have downloaded the instrument driver for Agilent/Keysight 8753B. So is it possible to use the same block Vi's for my device. Because, certain sub-Vi's can communicate with my device and since the working principle of majority of the network analyzer is the same, do you think it is advisable to try to use the same vi's for HP 8751A. Anyway, I have written some vi's for my device based on the concept of other instrument drivers as you have suggested.
Thanks for letting me know, that I am more or less on the right path.
07-09-2015 05:27 AM
Regarding the use of Instrument I/O assistant, it is mentioned on the web page of NI, that I/O assistant can be used when there are no instrument drivers.
file:///C:/Users/local-admin/Downloads/NI-Tutorial-4663-en.pdf
the last line mentions the same.
07-09-2015 05:30 AM
The progression for the company went HP's instrument division turned into Agilent. That division then split again into Keysight. So, yes, that driver should work unless they changed something major over the years (which I seriously doubt they would do).
07-09-2015 05:46 AM
07-09-2015 07:46 AM
Hello Guys,
in order to test the instrument driver of Agilent 8753 for HP 8751, it is asking for a saved state and saved calibration file. I am not sure, which kind of file should I upload in the directory pathway, for the labview program to run. I am completely lost and don't know what kind of a file is it. Can anyone give me some insight into this? or are there some files on the internet which I can use as default calibration and saved state file for running this Vi?
