I am doing a project on a Pulse Oximeter and i am trying to read and display the signal from my PIC Microcontroller on Labview? How do i go about doing it? I am using the PIC16F877 and also making use of the USART?
How do i implement and initialise the USART in PIC16? What are the steps to be taken, please guide me through the process? The link provides information regarding the USART connection, initialisting and stuff? Is it correct to use these codes in my program?Link: http://ww1.microchip.com/downloads/en/AppNotes/00774a.pdf
Also, i am using the RS232 serial interface to connect to the PC? The connector i am using is the DB9 Connector. Which template and VI can i use? Am i supposed to use the NI-DAQmx and VISA? Also, for my USART connection, i am using the MAX232 Driver which is applicable for my application as i am working with +5V. So far, i have been reading and trying out on Labview and the steps i have taken are:
1) Open a New VI and used the Instrument I/O(Read & Display) template?
2) How do i configure the Instrument I/O Assistant Express VI to read the info from my device connected to COM1?
3) I was reading the Labview Manual, 'Getting Started with Labview' and i was following the steps under Page 55, Communicating with an Instrument. Am i on the right track?
4) How do i check and make sure that the port settings of the I/O Assistant and my PIC Micro Match
Please help me out and guide me through the process. I am student at a polytechnic and i am very new to Labview and the software is used as a development tool for the project. I have a deadline to meet and i hope i can get a response as fast as possible. Your help will be kindly and greatly appreciated. I hope to hear from you guys soon.You can e-mail me all your answers at ashwinm@pacific.net.sg
Thank You
Ashwin
Ashwin Kumar Mansukhani
