03-05-2009 08:47 AM
Hi everyone
I am a labview newbie, trying to control an actuator through the newport SMC100 motion controler, using the RS232-USB kit. The system works fine as I can control the actuator through the Newport software. I have installed the Newport SMC100 labview drivers. The problem is I don't know really where to start with the block diagrams. What is VISA? How do I connect things? what do axes refer to? What com port to use? Does it work with the USB converter? Can I see the device in MAX? Anyone who has some sample code to share or pointers to resources would be greatly appreciated.
Magnus
03-06-2009 03:38 AM - edited 03-06-2009 03:40 AM
Have a look on this ftp and download what you need, there is a complete exemple to use the SMC100.
ftp://download.newport.com/MotionControl/Current/M
02-01-2010 08:27 PM
Hello MagnusBL,
I struggled greatly to try and solve the same issue - but especially because the examples given in the library don't always work, giving some of the errors referenced in other posts on this board (especially the dread Error -1073807298; see this). After much trial and error, including port monitoring using portmon, I found that labview was giving the same calls to the device as the supplied windows code, but needed to repeatedly check and clear errors after doing a reset command. The following screenshot shows what I did to get it to work, and I have included the VI below. YMMV. And my coding may be sub-optimal. Improvements appreciated. Finally, I am driving a micrometer (hence the rotate light).
Good luck,
RipRock99
06-17-2010 09:03 PM
Hi RipRock99,
I'm using your code but I change the VISA to serial because of usual VISA code. Your code is totally fine with me. I put the increment and multiply by 10 in first sequence between absolute move and tell current but it did not work. I wanna rotate the stage with increment with 10 and delay the position for a second in each increment in order to make the measurement.
Thank you
Z10
06-22-2010 01:49 PM
Hmm - without going back and breaking open my hardware and software, I don't know the answer. I am unfamiliar with the increment routine. If you figure it out, post it here for the record!
06-22-2010 06:07 PM
still trying
04-01-2012 08:19 AM
Dear RipRock99,
I am using your code, i have just one question.
In the front panel i can only enter the "position" "mm unit", i cant enter any decimal number: for example i want to go to 1,8mm or 1,03mm positions, it does not work! SMC 100 can go only to exact positions like "1" , "2", "3", "4" ..... "25"
Please reply..
Best Regards..
04-01-2012 03:54 PM
04-03-2012 04:19 AM
Thank you so much Albert.Geven
Your idea helped me to solve the problem.
Best Regards from Turkey!
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
