09-30-2010 07:45 AM
@popol21 wrote:
I have a problem I thought would be easily solved. But finally I can't find the solution myself.
Under Windows (XP), if I go into the Device Manager, I can see the list of my hardware, including the COM ports. I can see there an "identifier" of the port. For example, if I plug an USB to RS-232 converter (FTDI), I can see its name.
How can I have access to this identifier under LabVIEW?
Thank you in advance for your answer.
You see the (FTDI) name in the device manager because of the FTDI driver....
To access these informations I would call the FTDI dll functions with labview (like KC said)
But first would digg into the VISA properties,but I think you already looked into it .... (sorry currently no FTDI serial device nearby...)
09-30-2010 09:28 AM - edited 09-30-2010 09:28 AM
Ok, thank you KC and Henrik. I will follow your suggestion.
10-01-2010 01:31 PM
Have you tried to query the name using a VISA Property Node? Try the Interface Information->Interface Description property and see if it gives you what you are looking for.
-Jason S.
01-14-2011 04:21 AM
@ popol21: Have you successfully tried it with the dll? You can find LabVIEW examples at FTDI's.
The workflow would be:
1. get a full list of FTDI devices (dll)
2. search it for your desired device description (LV)
1&2: If you can ensure there's only one such device: Open it by description (dll) (FT_Open_Device_By_Description.vi)
3. get the COM port number of the device with that description (dll) (FT_Get_COM_Port_Number.vi)
4. get the ASRL... identifier according to the COM port number (VISA/LV)
4. open the COM port with a string ("COM " + number) as the resource (VISA) (you will see a coercion dot!)
5. do your regular communication with the VISA resource out (of VISAopen)
I hope this helps everyone using FTDIs!
01-14-2011 07:12 AM
Yes, I achieved to do it. Anyway, thank you for your answer. Indeed, if people are looking for FTDI identifier, follow the above instructions.
Thank you again.
