12-06-2014 12:53 PM
I want to do drivers via RS-232(serial line) for microbalance- communication with pc(remote control), i have manual with serial interface but i don't know how to use it for programming in Labview. Can you help or show me some similar programs? My main problem is how to create start output - line composed of 15 words.
I attached pdf file , main VI and subVI...I know it's wrong subVI, instead of write buffer should be line composed of 15 words according to pdf but I don't know how can i make it.Thank you for your potential help.
Solved! Go to Solution.
12-06-2014 02:25 PM
12-06-2014 02:41 PM - edited 12-06-2014 02:43 PM
Yes, I didn't find the drivers for this microbalance(kern pej 603-m) there.... I need to create in labview them. Do you think it's too complicated?
12-06-2014 04:11 PM
12-06-2014 04:28 PM
Ok, I am looking at it...i don't get it this part ....Can you explain me that, please? Why are numbers 2,1,6 there and what is abc character? Thank you, Dennis.
12-06-2014 06:51 PM
12-06-2014 07:29 PM - edited 12-06-2014 07:31 PM
Okay, up is subVI - calc weigh..i don't understand why is this so good if u can explain to me? Below it's used. I found "manual" - remote controls for their device. I attached my pdf manual of remote control "remotecontrol" as well - according these parameters need to change it...They have written characters like t,w,s...But in my manual is just hexadecimal codes, how do I use it? Thank you.
12-08-2014 08:49 AM
12-08-2014 10:30 AM
This is my weigh VI. I wrote [48-57] in decimal system. I found complete manual, on page number 85 is 0 - 9 (30 H – 39 H)=Data 0 to 9 (max. 6 characters in 6-digit format). Is it correct when i wrote [48-57] there? Can you modify my Weigh VI according my manual for show the output characteristics as shown in the manual for example: i would like to appear at the output signs(+-), weighted value with the units like "Continuous data output stable weighing values" of chapter 14.5 on page 88. Thank you for helping out.
