Now the problem is solved adding the structure you can see after the VISA resource name. That structure was in the program I told you in a later post that worked with those devices via Ethernet. The problem was in the shape of the commands I was sending and not in the Ethernet conexion.
In this case it is not necessary to list the instruments in the MAX.
