Thank you reply,JenK
The documents above seem like I need more adaptor or device to communicate with S7-300 PLC.
But my boss need to cut the price of initial cost, so there is a low cost way to do ?
So far I can read the data from serial port which connect with CP340 module's RS232 port.
but I don't know how to modify the PLC's register value so that I can control the the whole process.
Are there cheaper way except profibus using lookout?
BTW, I use this communication in HVAC system.
http://www.vitst.com
Virry Test & Control
LabVIEW Certified Developer
