Hello...
I have to use NI-485 with the application at the baud rate 460,800 bps. I prefer to check the baud rate first.
I've already try to check by using digital oscilloscope to capture some data bit from the port but the signal is very low and I got just noise.
What could be the solution for this problem..
Thanks for any kind help.
