How not to truncate the NI I/O Trace buffer value after export to txt or csv
I am trying to export a .nitrace file into txt & csv format, and I see that the buffer value is truncated after it gets exported, for example:
viWrite (GPIB0::20::INSTR (0x053AF520), "CONFigure:WLAN:MEAS:R...", 50, 50)
instead of
1850. viWrite (GPIB0::20::INSTR (0x053AF520), "CONFigure:WLAN:MEAS:RFSettings:UMARgin 20.00", 50, 50)
How can I make sure that I export the complete string and not just 24 characters?
Message 1 of 11
(8,745 Views)
Apparently this truncation dates back at least to 2012.
Someone asked for the ability to not have this happen, but apparently it has not been implemented.
http://forums.ni.com/t5/LabWindows-CVI-Idea-Exchange/NI-Spy-NI-I-O-Trace-CSV-txt-export-with-arbitra...
Message 2 of 11
(8,730 Views)
Thanks.
Message 3 of 11
(8,725 Views)
This is really bad. having a logging feature that does not function as planned.
greetings from the Netherlands
Message 4 of 11
(8,716 Views)
Hi Albert.Geven,
I would recommend posting a new request on the LabWindows/CVI Idea Exchange forum to request updates to this function. We're very appreciative of feedback and feature requests, but unfortunately can't always implement them. In this case, a new thread is more likely to garner attention than the three year old post.
Tom D.
Staff Software Engineer
NI
Message 5 of 11
(8,693 Views)
@TommyDunkz wrote:
Hi Albert.Geven,
NI I/O Trace isn't specific to LabWindows/CVI.
It is an utility that usually installs with NI-VISA.
Message 6 of 11
(8,677 Views)
Hi Tommy
I just made the remark that NI should take care of this.
Please generate a CAR for this. An application engineer should perfectly be able to do this, why should I generate a new thread?
Message 7 of 11
(8,613 Views)
Hi Albert.Geven,
Thank you for bringing this issue to my attention. I am looking into it, and will discuss with some colleagues to determine the next course of action.
I apologize if my previous post seemed dismissive. I meant to emphasize that posting on the Idea Exchange forums is typically the best way to bring attention to these issues.
Tom D.
NI
Message 8 of 11
(8,595 Views)
@TommyDunkz wrote:
Hi Albert.Geven,
The issue was posted on the Idea Exchange forum.
It may have been incorrectly posted in the LabWindows/CVI section when it should have been more accurate to place it in the NI-VISA section.
Nonetheless the issue is still there 3 years later.
Message 9 of 11
(8,587 Views)
Hi.
I had the same issue and I wrote myself a tool, that filters the text export from NI I/O trace in that way, that you have your full buffer in one line (CR / LF are replaced). Actually it only displays serial (com-) ports, that are really used (I search for VISA.Close..) and it is written for the german version of NI I/O trace, so you need to replace some constants anyway.
Here it is..
It needs OpenG String/Array installed.
BR
Marcus
Message 10 of 11
(6,948 Views)
