10-07-2014 06:07 PM - edited 10-07-2014 06:09 PM
I have multiple sensors that communicate via RS232. I found a 4 port to USB.
Since I have more sensors. Can I connect a few more NI USB-232-4 to other USB ports?
10-07-2014 06:10 PM
They just show up as COM ports. As long as they show up in the Windows Device Manager, I would say you were good to go.
10-18-2014 07:20 AM - edited 10-18-2014 07:21 AM
10-18-2014 07:22 AM
10-19-2014 08:47 AM
255 may be the theoretical limit but the practical limit will be less.
USB ports have a current limit.
10-19-2014 06:16 PM
10-20-2014 07:24 AM - edited 10-20-2014 07:25 AM
As far as I remember from my old days, you can hook up to 32 USB devices ..
And I had an application running with 4x 4RS232-USB ... the biggest problem was a robust system for the field (No USB isn't a robust connection, a screwed secured RS232 is 😉 )and to reliable identify the sensor to port configuration after reconnect/ USB port swap .....
10-20-2014 07:27 AM
Even when turnning off power saving on USB, I have seen instances where a USB connection will "disappear" in Windows.
A reboot of the PC would be required.
USB is to be avoided if possible.
