How many NI USB 232/4 modules can be connected to the PC?
I have multiple sensors that communicate via RS232. I found a 4 port to USB.
Since I have more sensors. Can I connect a few more NI USB-232-4 to other USB ports?
Message 1 of 8
(5,738 Views)
They just show up as COM ports.  As long as they show up in the Windows Device Manager, I would say you were good to go.
GCentral
Message 2 of 8
(5,734 Views)
If I remember correctely, max 255 RS232 com port.
Message 3 of 8
(5,633 Views)
255 may be the theoretical limit but the practical limit will be less.
USB ports have a current limit.
Message 5 of 8
(5,612 Views)
Yes, the USB port has a current limit, but if you use a usb powered hub, you can increased the number of device connect to the pc.
Message 6 of 8
(5,598 Views)
As far as I remember from my old days, you can hook up to 32 USB devices ..
And I had an application running with 4x 4RS232-USB ...   the biggest problem was a robust system for the field (No USB isn't a robust connection, a screwed secured RS232 is 😉 )and to reliable identify the sensor to port configuration after reconnect/ USB port swap .....
Greetings from Germany
Henrik
LV since v3.1
Message 7 of 8
(5,579 Views)
Even when turnning off power saving on USB, I have seen instances where a USB connection will "disappear" in Windows.
A reboot of the PC would be required.
USB is to be avoided if possible.
Message 8 of 8
(5,573 Views)
