Your comment about an indicator getting "clogged up with data" doesn't make any sense. The contents of a string or array indicator can get large and slow things down but a numeric indicator cannot get clogged up. If the data stops making sense, then you are incorrectly reading the instrument and converting that data to a numeric. With your comments about the device transmit buffer, I suspect you have occasionaly set the byte count too low and unread bytes are there that you then read the next time. As long as the instrument is fairly new, it will send out a termination character (typically EOI) that will terminate the read. You can then set the read count to some arbitrarily high number to ensure you've got the entire tr
ansmit buffer contents. It's also possible that you periodicaly have an error condition where the instrument is sending unexpected information. For example, if it normally sends a floating point number as a result and then it sends an error message string, you might not be intrepreting it correctly.
