07-21-2014 03:47 PM
I am using a FTDI Basic Breakout 5V [https://www.sparkfun.com/products/9716] to convert my LabVIEW serial signal into a DMX signal. The .vi is attached.
I am trying to find a way to be able to continuously send the DMX signal such that, ultimately, I can adjust the values to each channel using the sliders while the .vi is running. I would like to be able to see the changes in the output DMX device in realtime as I adjust the sliders. I would like to do this without having to stop the program, adjust the sliders, and run the program again to see the changes. Thanks in advance for your input.
07-21-2014 04:27 PM
07-21-2014 04:28 PM
07-23-2014 10:52 AM
This worked, thank you!
04-21-2017 04:34 PM
Hi
Do you know if I can use your VI with a ENTTEC DMXUSB PRO, I tried but does not worked....Can you help me please?
04-21-2017 05:01 PM
You cannot use a flat sequence like I said three years ago.
You have to send bitstreams when you want to change stuff so you need to send in a while probably and use subroutines (subvi's in LabVIEW) and some controls depending on what you want.
Please open a new thread and specify what you have and what you need to get working.
04-21-2017 05:18 PM
Hi Albert.
I really apreciate your coperation
I am student and I have a project for just turn on and off six RGB lights via DMX using sliders and control on/off of Labview and in the project I must to use a ENTTEC MDX USB PRO so, I was checking and found your VI, I connect but does not worked. Can you send me please the modificacions that you made to the original VI? or help me for the VI works.
Thanks so much
04-21-2017 05:34 PM
04-21-2017 05:55 PM
Hi, Albert.
I am using the VI in a flat structure (This is a problem but I don't now how resolve), I have connected via USB the ENTTEC DMXUSB PRO, and connected to this with XLR cable a DMX 512 Controller decoder and the RGB LEDS to the DMX 512 Controller decoder. When I run the VI, Labview identifies the connection with the ENTTEC, then, I write the values of the channels, but the LEDS does not turn on, that is the main problem, so I appreciate very much that you could share something that can help me.
Regards
