Have you first tested serial communication with your instrument using Hyperterminal? If not, then your cable or com settings might be incorrect. If you have verified communication with Hyperterminal, then you usually have to send a valid command before the instrument will respond. Most instruments require a termination character at the end of the command. Verify that the command you're sneding is correct and if necessary, add a termination character.
