Hi all,
First let me say that I am a novice when it comes to LabVIEW.
I am trying to send different voltage values to the +6V side and +25V side of an Agilent E3631A Triple output power supply. According to the front panel of the power supply, its working, but when I scope the output, only one side of the power supply is actually changing the voltage... I have tried several different power supplies, so its not a hardware problem. Does anyone have any ideas about what could be causing this?
I have also tried to go around the problem by controlling 2 different power supplies, but I couldn't get the 2nd one to do anything. I'm assuming its an addressing issue/problem, but I couldn't figure it out. An
y ideas on this issue?
A solution to either method would be very helpful, as either one would help me get this project done. Please help!
Thanks in advance!
P.S. I'm using LabVIEW 6.0
