12-02-2014 02:39 AM
I'm trying to use C# to control my GPIB equipment. As long as I use the default timeout, i can read/write/query with no problems. Today I wanted to try to change the timeout so I tried the following command:
mbSession = (MessageBasedSession)ResourceManager.GetLocalManager().Open(visaAlias, AccessModes.NoLock, 10000);
int originalVisaTimeout = mbSession.Timeout;
int newVisaTimeout = 120000;
mbSession.Timeout = newVisaTimeout; // this does not work and changes to either 3000, 180000, or 300000 depending on the values i've tried for the timeout so far
mbSession.Timeout = originalVisaTimeout // this correctly sets the timeout back ot the origianl value.
Am I using the wrong Timeout property to set the GPIB Timeout? The documentation shows the following information.
// Summary:
// Gets or sets the minimum timeout value to use in milliseconds when accessing
// the device associated with the session.
// Exceptions:
// NationalInstruments.VisaNS.VisaException:
// The property is set to an invalid state.
// System.ObjectDisposedException:
// This member is called after the Dispose method is called directly from code
// or indirectly through a finalizer.
// System.DllNotFoundException:
// The NI-VISA driver library cannot be found.
// System.EntryPointNotFoundException:
// A required operation in the NI-VISA driver library cannot be found.
public int Timeout { get; set; }
Frank
12-02-2014 07:49 AM
I would just use the largest timeout value I would need.
Does the code work if you start the session using 12 seconds instead of trying to change it from 10 seconds to 12 seconds?
12-02-2014 07:55 AM
By default, the session starts with 3 seconds. I can get the session to use a high timeout so that it works, but i'd still have it set the timeout to the value I define. I'm thinking it is possibl that this timeout is not the correct property to set. By the way, that first line of code whic has the acquire, well, there is that 10000 that is passed in. That 10000 does not define the GPIB timeout but rather a timeout to acquire the conection. So basically, I want to change the timeout as a property that I'm passing in from a configuration file (code not shown for that), but no matter what, the mbsession.Timeout does not equal the value I choose unless I choose 3000, 180000, or 300000. For other values I've tried, as an example, 100000, the setting is rounded to 180000 for some reason. This just makes me think I'm doing it incorrectly. I'd rather it be working as expected rather than just working.
12-02-2014 08:33 AM
I am at a different PC, but you need to do something like mbSession.SetAttributeInt32( , )
http://zone.ni.com/reference/en-XX/help/370627F-01/mstudiowebhelp/html/ed6dead2/
12-16-2014 09:02 AM
I couldn't figure out how to do anything with what you mentioned, but here is the weirdness of the valueToSetTimeoutTo vs valueActual. I'm not sure what the deal is with 1s and 3s, but they seem to be the trigger point for a new timeout.
Attempt | Actual |
3000000 | 1000000 |
600000 | 1000000 |
500000 | 1000000 |
400000 | 1000000 |
350000 | 1000000 |
300001 | 1000000 |
300000 | 300000 |
180000 | 300000 |
100001 | 300000 |
100000 | 100000 |
30001 | 100000 |
30000 | 30000 |
10001 | 30000 |
10000 | 10000 |
12-16-2014 10:02 AM - edited 12-16-2014 10:04 AM
Attempt Actual 3000000 1000000 600000 1000000 500000 1000000 400000 1000000 350000 1000000 300001 1000000 300000 300000 180000 300000 100001 300000 100000 100000 30001 100000 30000 30000 10001 30000 10000 10000
All of that is pointless.
If you are not understanding what to do, then you are just running in circles.
12-17-2014 01:53 PM
Well, as it turns out, the behavior is the correct behavior. Go figure. Opening NI Max and trying to adjust the timeout, you have 17 options (a subset is shown below):
Disabled
10 usec
30 usec
100 usec
300 usec
100 sec
300 sec
1000 sec
Problem Solved.
12-17-2014 02:54 PM - edited 12-17-2014 02:54 PM
Disabled
10 usec
30 usec
100 usec
300 usec
100 sec
300 sec
1000 sec
Problem Solved.
I was certainly able to set a timeout to 9000 (9 seconds) for a network analyzer data read.
12-17-2014 03:11 PM
It is possible that i'm looking at the wrong property. But if you open NI Max, go to the properties tag, and open the dropdown menu for I/O Timeout, you can see what i"m talking about. Did you verify that it was set to 9 seconds by reading the timeout after you set it?
