This is not supported with PnP PCI-GPIB cards. PCI does not have the same addressing scheme as the ISA bus. I don't know of a way to map addresses from an IO address to a PCI address.
This functionality will only be fully supported with our non-PnP AT-GPIB/TNT cards. You should see if Fluke has updated software that does not depend on these base addresses.
Craig A.
National Instruments Engineer
