I am not certain if you are using LabVIEW or a C based language. The instructions will change a bit. The easiest way is if you are using a C-based language. If you open up a board session (i.e., ibfind ("GPIB0")), you can use the returned handle to make a board-level call. To address the bus, you need to make a call to ibcmd. The commands that you want to send across the bus are UNT, UNL, MLAdevice. The characters are:
UNT = '_'
UNL = '?'
MLAdevice = 0x20 | PAD of the device
You can make 3 ibcmd calls, or you can create the string and make a single ibcmd call (fastest).
I hope this helps.
