Hi Andrei,
Unfortunately CVI for SUN does not include a distribution kit packager for your applications. What I would suggest is to find a 3rd party packager and include the executable as well as the shared libraries that are part of the runtime engine. This list of files should be documented somewhere either in the runtime or when you installed CVI. I would first look on your machine to see if you can find that list of files. Then, just add those files to the package and you'll be set. Hope this helps!
Jeremy L.
Jeremy L.
