Hi, I am new to Labview. The current goal for me is to read data on the RS232 port which is sent out by others. Since I don't know when will there be data on the RS232 port, I wonder if I can do event driven serial communication: when the RS232 port receives some data, it will put into some buffer and notify me, then I read all the data and clear the buffer.
I have written a small VI which took a while loop and polling the RS232 port. The problem with polling is that I don't know how to remember last data. Here is the flow: in a while loop, use "bytes at serial port" and "read serial port" to read the buffer data, and user string conversion function to convert it to decimal number, and link the decimal
number to a wave form. But when there is no data on the RS232 port, the string conversion will convert it to 0. How can I tell the string conversion function not to convert when there is no data on the RS232 port?
