It would help if you mentioned what software you're using. In LabVIEW, if your'e using VISA Configure Serial Port, the default setting is to stop the read when the termination character is detected and the default termination character is x0A. To read past the termination character, all you have to do is disable the termination character. I'm sure there's a similar VISA setting when you use other programming languages.
