Hello Massimiliano,
Thanks for contacting National Instruments.
To answer you question, the best way to do what you are looking to do is to use the instrument I/O Assistant to generate whatever you want the code to do without the non-displayable characters, then once the Instrument I/O Assistant block is on the block diagram, then right click on the Assistant block and select to open the front panel. You will want to choose to convert it to a standard VI, which will allow you to change the code that has been auto generated. In order to add non-displayable characters to this code you follow the knowledgebase link below.
http://digital.ni.com/public.nsf/websearch/77c8f61d36f5a23086256634005acb38
Hope this helps!
Steven B.
Applications
Engineering
