Hello Kai,
thanks for the answer.
But as I wrote, I haven't a GPIB card in my developement system. So I need no access to the functionality. The GPIB card is in a measurement system.
I write a new programm for those measurement systems.
For writing the programm I need the language interface on my developement system. The GPIB card is installed on the measurement system.
So why should I install a non existing hardware to get two files from a CD?
Why should I installed a software which say allways 'You haven't the proper hardware' ?
I can't develope on a measurement system. They are needed for manufacturing.
The best solution will be to install all on a new system, copy the two files an than kill the new system.
Best regards
Ulrich Debler
