Pushpa,
"split number" is certainly the VI that I would recommend you use. Keep in mind that it splits the input into two equal parts. If you input a 32-bit integer, the high 16 bits and low 16 bits correspond to the two outputs. You'll then need to split one of the previous outputs into its high and low components to access each individual byte.
You could also construct a mask, bitwise AND it with your number, and then shift the result the appropriate number of bits. However, for the sake of simplicity, I recommend that you use "Split Number."
Alan
