10-02-2015 04:01 PM
I've created code to control my instrument. I want to add the ability for the user to select a standalone SFP from the MAX menu.
Solved! Go to Solution.
10-02-2015 05:55 PM
10-02-2015 06:01 PM
It isn't an IVI driver. For instance, I recently created a simple driver to control a USB to I2C device (The NI one and another model). I created it into a TestStand step type. I'd like to also have a stand-alone version of the code that doesn't require TS so I want a SFP version of the code.
10-02-2015 08:56 PM
10-05-2015 02:17 PM
I certainly wouldn't have guessed that. It's wierd that things like NI-Switch, NI-Scope, NI-etc are in the list but not IVI-Switch, IVI-Scope, etc.
I'll look into making an IVI instrument driver out of my code.
Thanks for the info.
10-05-2015 02:23 PM
10-05-2015 02:38 PM
I don't really have a need to launch from MAX. I have used the SFPs from there several times during development/debug. They can be quite helpful. It would be nice to be consistent with the way NI provides them. The users of my tools could find the SFP in the same place as NI privided ones.
10-05-2015 05:01 PM
