JLS, Thanks again.
I expect to receive my "actual" laser sensors with serial output in 2 days. We've been working with a poorer standby system (which has been not easy to work with).
I will revert back to this discussion if I continue to face issues with my new sensors (make: LMI Selcom, Sweden)).
Should I place my query here or would you like me to write to your directly over email? It would be nice to have your email id, just in case. My email id is "gurdas@qagetech.com"
I had some thoughts on your above reply:
"Say I configured my FIFO size to 4 bytes. But my read vi is not always active. Its turn comes once in a while. What happens when the FIFO receives 4 bytes but there is no read vi active? Will it forc
e my read vi to get activated? That is something I do NOT want. Or will the FIFO simply start to receive the next 4 bytes thus losing the current 4 bytes. Or will the current 4 bytes move automatically to some CPU memory where I can access it later?
Also, if I do not read the 4 bytes when they arrived, and the next 4 bytes start coming in, will it not result in a continuous interrupt since the bytes if FIFO will always be 4!! (0123, 1234, 2345, 3456 ...). I am unable to flush because that too is happening only before my read vi."
Best,
Gurdas
Gurdas Sandhu, Ph.D.
ORISE Research Fellow at US EPA
