I'm having some troubles. I've been using the dpib32.pas library for at least 2 years now with no troubles. Now I need to handle some oddball stuff using Async Callbacks. I've referred to App Note 100 and am 98% there... I just can't figure out how to properly use the TCallback function in ibnotify. Any clues?
First thought was to add a function matching the TCallBack function...
function TfrmMain.IBCallBack(ud : integer;LocalIbsta : integer;LocalIberr : integer;LocalIbcntl : Longint;var RefData): integer; stdcall;
then use it as a the parameter in ibnotify...
ibnotify(Dev,RQS,@IBCallback,NULL);
All this gives me is a 'variable required' message on compilation.
