Hi ct,
It depends on the device if it takes a secondary address or not. There are two options:
- No secondary address: just use the primary address. Set the address argument to the primary address (0 to 30).
- Secondary address: You need to specify BOTH the primary and the secondary address. These two addresses are packed in the same integer. The primary address in the lower byte and the secondary in the upper byte.
Check out chapter 4 of the
NI-488.2M Software Reference Manual. I think this is the manual that describes it better.
DiegoF
National Instruments.
