07-06-2005 02:39 PM
07-07-2005 04:19 PM
07-07-2005 10:52 PM
Is your problem just a matter of display, or are you receiving a floatting point number under machine format (ie 4 bytes for a single precision float) ?
In the latter case, use the type cast function as in the attached vi. Depending on the connected instrument, you may need to revert the byte order in your hex number to read something understandable.
