06-29-2010 07:59 AM
... ok so look at AK2DM's diagram, short out pins 3 and 5 on the mini-DIN and do your loopback test.
06-29-2010 08:00 AM
I made a mistake by looking at an example of a minidin connector on Google images instead of looking at the manual for the one actually included with my device. My other question remains though. Any advice for how to run the loopback on such a small cable?
06-29-2010 08:08 AM
Small solid core wire? Just wedge it in the two pins.
06-30-2010 09:19 AM
The loopback test has failed on the cable. Thanks for your help everyone. I'll have to have the professor I'm working for take a further look at our setup.
08-25-2010 05:11 PM
Iceman,
If you're still working on this project, and have set this thread to notify you of updates, reply back to me. I have LV code that communicates reliably with Alicat meters/controllers, perhaps you would want to try it. Post back here so I can get your email address.
Dave
09-05-2011 07:43 AM
Hi David,
Are you still there? I would very much appreciate a copy of the drivers you have developed are you willing to share with me? Seems a shame to start from scratch.
-Martin
09-05-2011 10:24 AM
Martin,
Here as always. I've replied to your email address.
Dave
02-21-2013 09:20 AM
Does anyone know how to change register 20 on an Alicat MFC? I am trying to make it a pressure regulator. Thanks!
Deana
02-21-2013 10:31 AM - edited 02-21-2013 10:35 AM
Deana,
If you can access the device via Hyperterminal, read register 20 by typing:
**R20 (followed by a carriage return)
The device should respond with the text of the register's 16-bit value as a decimal number.
The best way to approach this is to think of the value as a bitfield; the info I've pasted below shows most of the bits that comprise the selection options for that register.
Looks like you want to change the device from a mass controller to a pressure controller. That's esssentially a three-bit field at bits 10 thru 8.
If you want to control upstream rather than downstream pressure, you'll also want to set bit 15 to invert the PID loop.
You will almost certainly need to retune the loop parameters after having changed this... registers 21, 22, and 23.
Edit: Ooops. In Hyperterminal, write a new value to register 20 by typing:
**W20=<nnnnn> followed by a carriage return, where <nnnnn> is the new value as a decimal number.
PM me if any of this is unclear.
Dave
Bit(s) Set Clear bit 15 Vacuum/Back Pressure Pressure bit 14 Analog Setpoint RS232 Setpoint bit 13 Auto Tare No Auto Tare bit 12 4-20 mA Setpoint 0-5V Setpoint bit 11 Local (Front Panel) Setpoint Analog or RS232 bit 10-8 Controller Select 100b = Mass Flow 011b= Volumetric Flow 010b= Temperature 001b= Pressure 000b= No Controller
05-14-2014 03:00 PM
David,
I am also working on project with Cole Parmer MFC's and I came upon this thread when looking for help. If you are willing to share your code for communicating with the MFCs (I believe that Cole-Parmer MFCs are Alicats that are just branded Cole Parmer), I would greatly appreciate it. I am hoping to use Labview to control several MFCs as well as data-log their outputs.
Thank you,
Dylan
