There isn't a way to acomplish this using the VISA resource names. VISA can only do what, in this case, GPIB can do.
Channel information is instrument specific. The GPIB specification does not define any mechanism to address different channels on the device. These are handle using the instrument-specific data commands.
The only mechanism that might be use to directly address channels is secondary addressing, but is the instrument manufacturer who defines this behavior. Check the documentation of the instrument to determine how different channels are addressed. If the instrument uses different secondary addresses to access channels, you could have different resource names for each channel.
DiegoF
National Instruments.
