07-25-2016 02:05 PM
We have sevral test stations running LabVIEW 2011 that contain a HP6633A power supply. Recently, we have not been able to get HP6633A from our vendor so someone purchased the HP6633B instead, thinking it would be a drop in replacement. Turns out, it's not, the VISA command set is totally different. I'm posting this on the off-chance that someone has developed a driver that can talk to both, or at least a driver for the HP6633B that is LabVIEW 2011 complient. The only driver I could find for the "B" model was for LV2012 and up. I understand I should talk to Keysight, and I am doing that in parallel with this post. Just hoping to get lucky. Thanks, Pat
Solved! Go to Solution.
07-26-2016 07:22 AM
You should be able to switch the new power supply between old compatible and new command language using the SYST:LANG Command ( See Appendix B of devices programming guide)
07-26-2016 09:02 AM
Thank you for pointing this out, you saved me a lot of work!
01-24-2018 10:33 AM
Check the LANG selection in the Power supply. I use the 6632A and B versions. The A versions have the COMP language while the B versions are SCPI compliant. You can choose COMP in the B versions and they will act like an A version supply. It is a setup within the power supply, I typically use the NIMAX to check the setting and make the change there. It will hold this in memory even after power cycling.
Cheers!
