HP6060B: I have not found in ni.com and in agilent.com the instructions or some example codes in visual c++ to control via GPIB this intrument. Can anyboby help me? Thank you very much.
HP6060B: I have not found in ni.com and in agilent.com the instructions (or some example codes in visual c++) to control via GPIB this intrument. Can anyboby help me? Thank you very much.
(3,436 Views)
Marco,
It appears that Agilent has an instrument driver available for the 6060B in the following location:
VXI plug&play drivers for 606xB Series DC Electronic Loads
The programming manual for this device is also available on Agilent's website. It is available in the following location:
605xA, 606xB, 6050xB Electronic Loads, Modules, and Mainframes Programming Manual
Good luck with your application.
Spencer S.
(3,436 Views)
Thank you, but I have already solved my problem about this instrument using visual c++. Thank you the same.
Marco
(3,436 Views)
