Hi, I`m trying to use Labview and GPIB with the analyser HP 8510C, but some errors are ocurring. All the cables are correctly installed.
Someone knows why a little red light appears on the left side of the CRT (display) ? When it happens i lost communication with the PC.
When I use at the first time the Getting Started.vi it works perfectly. But then if I try to use again, this red light appears and I lost the communication.
If I turn off and then turn on again the instrument, sometimes the red light goes off and sometimes it continuous on.
Someone Can Help??
Thank you!
Raphael
